iot-device-type-imagotag-policy
Creates an IoT Device-type Imagotag policy and enters its configuration mode. Use this option to enable support for SES-imagotag‘s Electronic Shelf Label (ESL) tags on WiNG APs.
Important
Important
  • This feature is supported only on APs with USB ports.
  • Ensure the AP is using PoE+ (802.3at) power for the USB port. See power-config to set the power mode.
Your AP will not communicate with the ESL server with any exisiting or older versions of Imagotag configuration.
ESL tags are small, battery-powered devices used by retail businesses to display information, such as product code, pricing, and more. These tags are activated, configured, and managed through an SES-Imagotag server. The tags and server communicate through an ESL communicator (a USB dongle) connected to the USB port on the WiNG AP. This communication is over the 2.4 GHz band using a proprietary RF protocol. The ESL communicator acts as a bridge between the tags and the server, using WiNG AP as an infrastructure device.
This policy enables the ESL communicator, identifies the Imagotag server host, configures the payload size, and more. Apply the policy to the AP‘s self (in case of stand-alone AP) or profile context. When applied to the profile, the policy is pushed to the AP through the adopting controller.
Important
Important
On the Imagotag server, configure the WiNG AP's ID. This enables the server identify the WiNG AP. Use the show > iot-device-type-imagotag > status command to obtain the WiNG AP's ID. Refer to the Imagotag server configuration guide for more information.
Platform support:
Syntax
iot-device-type-imagotag-policy <POLICY-NAME>
Parameters
iot-device-type-imagotag-policy <POLICY-NAME> Specify an IoT Device-type Imagotag policy name. If a policy by the specified name does not exist, it is created.
nx5500-85FA27(config-iot-device-type-imagotag-policy-Default)#?
Iot Imagotag Policy Mode commands:
  ap-id              Configure AP ID
  channel            Configure ESL channel
  enable             Enable ESL communicator
  fcc-mode           Enable fcc compatibility mode on ESL communicator
  no                 Negate a command or set its defaults
  output-power       Maximum output power
  payload-size       Configure payload size
  server             ESL server
  ssl                Enable ssl on ESL communicator
  ssl-cn-verify      Enforce SSL Common Name attribute verification
  ssl-strict-verify  Enforce SSL strict verification
  trustpoint         Trustpoint for server CA certificate
  window-size        Configure window size
  clrscr             Clears the display screen
  commit             Commit all changes made in this session
  do                 Run commands from Exec mode
  end                End current mode and change to EXEC mode
  exit               End current mode and down to previous mode
  help               Description of the interactive help system
  revert             Revert changes
  service            Service Commands
  show               Show running system information
  write              Write running configuration to memory or terminal
Imagotag secure connectivity
Beginning with WiNG 7.4.0, the Imagotag ESL solution supports secure connectivity between an AP and ESL server on-prem or on-cloud. Any unencrypted mode of communication between an AP and ESL server is not supported starting with WiNG 7.4.0 release and onward.
You must upgrade your existing on-prem ESL server and add new parameters to the iot-device-type-imagotag-policy to enable a secure connection.
Ensure that your ESL server is migrated to latest version supporting outbound connection mode and encrypted communication support.
Imagotag secure connectivity is supported in the following platforms:
  • Access points – AP310i/e and AP410i/e
Related Commands
no Deletes the specified IoT Device Type Imagotag policy
